Texasmark1
Was reading a thread about 861 oil pressure this am and thought about this: I have a 4 cyl 2000D and have had it for 10 or so years. I run 15w-40 C rated oil in it and have since I got it. I change the oil when it starts getting dirty which is about once per year with filter. Uses no oil to speak of, original, 3500 hours and proofmeter works.
Question is: my oil pressure runs over 50# cold and has since I got it and only after the tractor has been worked real good does it come down to around 50.
Have heard that on gas engines, which turn the oil pump shaft with the distributor, high oil pressure puts undue stress on this shaft.
Other thing I have heard, and I have 3 or 4 Ford manuals including the entire shop manual series for the hundred series tractors, that Ford, like JD (4020 6 cylinder for one) has an oil pressure regulator valve set at 30#.
Initially I thought that if it had one it might be dirty and maybe twas because of using non det. oil when new (PO), or just it's age (1963 model). I figured that if that were the case, over time my HD oil would wash out the crud and it would start functioning.
Well nothing has changed over the years.
Ideas?
Thanks,
Mark
Ideas?
Thanks,
Mark
