Bought an aftermarket gauge to replace the non working gauge on my MF165 diesel. I wanted to replace the original with one that read by pounds of pressure, not low, medium or high like the original. My question is, the new one came with a small diameter plastic line, that looks to be half the diameter of the original metal tubing line. I believe the size of the connector is the same. Can I just swap out gauges and keep the metal line or will this effect the accuracy of the gauge? I would prefer the metal line over plastic but I wonder if the gauge may be "calibrated " for the diameter of the plastic line provided? Any input as to the accuracy of the gauge if I were to use the larger diameter line? Thanks
