Oil pressure light
Mack69
The oil pressure light doesn't burn when I turn the ignition to acc on my John deere 1020 tractor. What could be causing this
Check the bulb then check the complete assembly as they do rust. It could be as simple as cleaning everything up or the oil pressure sender could be bad. Sometimes it is just a ground issue. Just fixed both lights on a 4020 last week. One bad bulb and one very rusty assembly. Tom
You may be able to screw a gauge into the pressure sender hole. I did that on
mine...I prefer a gauge to a light. Some of the time, the light is hard to see in
the sun's glare.
Ben
(quoted from post at 08:52:07 07/07/21) Does it work when you turn the key to ign? Or does it not work at all?
Should the tab on the top of the sensor be connected to ground
(quoted from post at 11:09:59 07/07/21)
With the engine NOT running/no oil pressure the pressure switch should be "closed" and the tab/terminal at the top should show continuity for chassis ground.
Also, you can "ground" the wire that connects to the sender/pressure switch and the oil pressure light should illuminate.
(quoted from post at 11:17:27 07/07/21)
Thanks that's what I thought. My oil pressure sensor is not.
(quoted from post at 16:22:43 07/07/21)
/quote]
Have you removed the wire from the sender/pressure switch and grounded it to the chassis/engine and checked to see if the light comes on when the key is turned on with the wire grounded? If the light comes on with the wire grounded the sender/pressure switch is likely the problem. If it doesn't come on, there is a problem with the light or wiring.
You asked: " Should the tab on the top of the sensor be connected to ground"
No, The sender/pressure switch grounds internally if it only has one tab, it does not need a ground wire. What did you use to test it?
(quoted from post at 15:23:48 07/07/21)
/quote]
A multimeter. I ran a wire from the bulb socket to ground and it did burn
You said: "I ran a wire from the bulb socket to ground and it did burn." Did you also unhook the wire from the sender and ground the wire on that end? The bulb should burn, that will tell you if there is a break in that wire between the socket and the sender, which would keep the light from working.
If you unhook and ground the wire at the sender end and the light burns; and your multimeter does not show continuity to ground between the tab on the sender (with the wire off it) and the base of the sender where it screws into the block, the sender is no good.
No those are fully insulated terminals so I couldn't but I did connect the wire that I used to test the socket to the bulb and the oil pressure sensor and the light didn't work so I'm pretty sure it is the sensor
With this info I would say things point to the sender. And you checked the sender tab, with the engine not running, for continuity to ground with your meter and got nothing, correct?
As for checking insulated terminals, you can make a jumper from a male spade terminal and a couple inches of wire that you can plug in the terminal without damaging it. A short piece of wire or paper clip will usually work as well. These type test jumpers give you access to ground something or check for power without damaging the insulation.
Yes I checked from the sensor to ground and got nothing. I'm probably going to replace the wire anyway. I've replaced all of the other wiring
