(quoted from post at 21:17:49 05/10/16) I'm not liking your "rule of thumb". Allowing 20 PSI at 2000 RPM is asking for trouble.
(quoted from post at 22:17:23 05/10/16) The original poster did not mention whether his engine is gas or diesel, but I'm leaning towards diesel if it's a backhoe. This being the case, there's no way your rule of thumb will work in a diesel. Semis are motoring down the highway today at 1200 RPM. They wouldn't last an hour with 12 PSI of oil pressure.
(quoted from post at 22:25:06 05/10/16)(quoted from post at 22:17:23 05/10/16) The original poster did not mention whether his engine is gas or diesel, but I'm leaning towards diesel if it's a backhoe. This being the case, there's no way your rule of thumb will work in a diesel. Semis are motoring down the highway today at 1200 RPM. They wouldn't last an hour with 12 PSI of oil pressure.
Diesels actually have two stages to the oil system, they have a high volume system that is also high pressure and they also have a low pressure system which is just like a gas engine. This low pressure system delievers oil to the high volume pump to provide high volume and pressure where it is needed such as oil driven fuel injectors. But besides that, diesel engines still have the same oiling system as a gas engine.
As I said you don't want to believe this rule of thumb that is known in the automotive world don't, but don't try to be patronizing to someone that actually works in the automotive field and knows about the internal workings of diesel and gas engines. A diesel engine is no different than a gas engine, the main difference is a diesel engine has no ignition system as it uses compression to fire the cylinders. Besides that the crank, and rods, and pistons don't know they are in a diesel engine or a gas engine and oil is still supplied to cool and lubricate which even at 10 psi at 1000 rpm is still able to provide this function.
Its like the crowd that thinks for a performance engine you need a high volume high pressure oil pump but yet talk to the real engine builders they will tell you it does nothing but cause excessive load and wear and tear on your engine turning that kind of pressure. Plus oil pumps have a internal pressure regulator once pressure reaches the preset anything over will be dumped back into the oil pan thus negating the purpose of lubricating the engine.
(quoted from post at 23:38:36 05/10/16)(quoted from post at 21:17:49 05/10/16) I'm not liking your "rule of thumb". Allowing 20 PSI at 2000 RPM is asking for trouble.
Well don't, but GM, Ford, and even Chrysler did this test and found out for any engine be it a race engine or a stock engine 10 psi per 1000 rpm is safe. Anything more than 10 psi per 1,000 rpm is putting extra load on the dist to spin the oil pump resulting in more stress on the dist/oil pump as well as higher fuel consumption.
But if you don't want to follow it, don't. But the whole automotive world knows of this rule of thumb for oil pressure.
(quoted from post at 05:50:34 05/11/16) There's a simple solution to this argument....call Cummins sometime (or Cat, Detroit, Mack, JD, or the diesel engine manufacturer of your choice), and ask them if 10 PSI oil pressure is adequate for an engine that is working at 1000 RPM. Then ask them if 20 PSI is OK for an engine working at 2000 RPM. They will all say without a doubt: "H-e-double-toothpicks no!".
Engine builders today are trying to squeeze every last drop of fuel economy from today's engines, and you're right, excessive oil pressure works against that goal. However, they aren't going anywhere near your "rule of thumb". As an example, minimum oil pressure spec for a Cummins ISX (the most popular semi-truck engine on the road today) is 35-40 PSI at working speeds. Working speeds are around 1500 RPM.
As for there being no difference between gas and diesel, consider that a diesel operates with far greater internal forces than a gas engine, especially on the power stroke (i.e. torque). I'd argue that while adequate oil pressure is important in a gasser, it's even more important in a diesel.
I would agree with you that engines don't benefit from excessive oil pressure, however, as I said earlier, suggesting that 20 PSI @ 2000 RPM is OK is dangerous advice. Many OEMs would seem to agree with me.
(quoted from post at 07:57:26 05/11/16)
With diesel engines with oil driven injectors having completly different requirements,,
YES... The industry is moving to lower oil pressure and lighter oils that are BRANDED and certified to produce a minimum of 2% or more in fuel economy with out increasing wear over conventional xx-40w oils. 5w30 and 5w20 oils are becoming the norm in NEW engines. And yes the oil pressure rule is out there. Additional oil pressure over whats is required, is wasted energy and non productive. So... lower pressure and thinner oils are the norm, BUT higher volume pumps may be at play here.
HOWEVER... in old engines, especially engines that have run oils from the 60s and 70s that were NOT good oils and have more wear, and NO oil coolers, and sludge build up,, I dont think I would be in a hurry to change to a thinner oil. Fuel economy is not nearly as important as keeping worn bearings lubricated and a lubrication barrier between excessive clearances.
In this case of high oil pressure, I would suspect the gauge first,,, and or blocked oil passages, and or bad relief valve. Or maybe running tar (cheap oil that has broken down) or 90 weight oil instead of fresh clean 15w40.
(quoted from post at 10:45:42 05/11/16) The 6.7L Fords do not need "super high oil pressure" to run. The 7.3L and 6.0L engines did, but not the 6.4L or 6.7L Fords.
(quoted from post at 10:52:54 05/11/16) the 10 per 1,000 rpm rule of thumb comes from Smokey Yunick and his racing history with small block chevy engines
(quoted from post at 12:52:26 05/11/16) cummings.
(quoted from post at 15:41:57 05/11/16) "Lower oil pressure means more volume which means more oil is being applied to the bearings"?
Really?
(quoted from post at 14:32:37 05/11/16)
Wrong on the 6.4. Have one in the shop right now that has low volume pressure but no high volume pressure. It will not run without high volume pressure as it is not a common rail system. That came in the 6.7 the 6.0 and 6.4 are nearly identical.
As far as trust goes, you must have a hard life to sit and be a internet warrior. You think im lying go ahead i dont care but you sure seem to be going out of your way to prove what i said is wrong. In doing so youve made it clear to me you dont know what you think you do especially with the manure claim the 6.4 and 6.7 are common rails even though i have one torn down at work that is a 6.4 that needs a high volume pump.
Now as far as lower pressure equals more volume its true. Thats why lighter weight oil results in not just lower oil pressure but more oil thrown on the cylinder walls. Can get to be so much that it could overwhelm the rings and result in burning oil and smoking.
(quoted from post at 18:54:34 05/11/16) Rusty,
Did I ever call you a liar? NO! A liar is someone who spreads false information INTENTIONALLY, and I do not believe that you have done so. I simply said that you stated some things that were in error. The 6.4L engines as used in the 2008-2010 Ford F-series pickups ARE IN FACT common rail, as is the later 6.7. The earlier 7.3 and 6.0L engines are in fact HEUI engines. I challenge you to prove me wrong here. Trust me, if I were wrong, someone here on this board would correct me, you can be sure of that.
On the flip side, you call ME a liar, when I provide evidence from the #1 builder of diesel engines that I am correct, and that your "rule of thumb" is wrong. Something is really wrong with that Rusty. Now, this normally wouldn't be that big of a deal, but when you make a blanket statement the way you do about oil pressure, someone might believe you and choose to ignore low oil pressure in their engine. If they do, they could spend thousands of dollars more than they need to to fix the problem.
Again, I'm really not trying to be a jerk here. I'm simply trying to correct the record. I show manufacturer's specs, and you point me to the internet. Sorry, but I'll trust the engine manufacturer over someone else's opinion.
(quoted from post at 22:59:59 05/11/16) http://diesel.org/nozzle/powerstroke-6-4l-engine-and-fuel-issues
Straight from ADS, the Association of Diesel Specialists. They clearly state that the fuel system is common rail.
You're right, if we can't agree on what kind of a fuel system a 6.4L Ford (International) engine has, then we might as well stop right here.
(quoted from post at 23:11:22 05/14/16) About the faint knock . . .
Don't get me wrong, it bothered the heck out of me. As you know I am a mechanical worry wart about the slightest thing.
I was just saying that if you baby it, you can use it [b:4304d29fa2]until you get around to rebuilding or dealing with the offending rod[/b:4304d29fa2], which should be your ultimate intention.
In my case, I sold the car cheap to a couple who came all the way out from Alberta to trailer it home. They wanted it because they had gotten married in the identical car. And yes, I told them about the faint, muted knock which they couldn't even hear.
So don't go telling me I have the mechanical sensibilities of a woman. That is if you don't want me thinking that people here relish the chance to subtly call someone a fool.![]()
