oil pressure tube source
INCase
put new oil pressure gage and need new line from the block to the new gage.
What is a good source for these?
Thanks.
A good hardware store should have what you need.
I used small diameter soft copper (1/8" I think) and compression fittings. It's easy to bend around a v-belt pulley to prevent kinking.
Paul
I buy the 1/8 copper tubing by the roll and use it for oil pressure gauge line, gauges come with that plastic stuff that is not worth a dime but the copper stuff works real good and the fittings are not all that hard to find for it. Any good part store or hardware store should have it
What hardware stores are you guys getting that small copper at? Every hardware store in the Des Moines area I've stopped at says no way can't get it that small any more.
