I recently re-built my 9N, forgot to grease up the oil pump to prime it. So I went thru the pressure by-pass fitting, that did not work.
I also installed a new Governor and ran the oil line from the bottom of the canister, blocked off the line to the block, and kept the rear block fitting from the canister, which also feeds the gauge.
It seems that when I fill the oil filter canister, the filtered oil is going to the governor and is leaking out to the pan, which in turn leave a void in the canister.
My thinking is the pump is filling the canister, and won't show pressure until it full.
As a thought .... why can't a check valve be put in the pick up tube
Bob
Bob
