I bought a tractor with a set of new crank and rod bearings in it. The oil pressure was low, so I just rebuilt the pump and did gain some pressure. But, the pressure drops to near Zero after the engine comes up to operating temperature. I begining to believe that the crank may not have been ground and match fit with the new bearings. I really do not want to take the engine out, now that the tractor looks good. I would like to know if the oil pump provides oil to the cam first or does it provide oil to the crank main bearings first. I will pull the engine if the cam bearings need to be replaced. If the crank mains are the first, I may consided a small size main bearing to compansate for the crank size. Tell me what you believe. This is a very early 1940 model.
