Oil pump discharge pipe
Gpacer58
Where the oil pump discharge pipe goes in the block there looks like theres a rubber orifice in the hole can anyone explain to me what this is for
(quoted from post at 23:39:55 12/24/23) Where the oil pump discharge pipe goes in the block there looks like theres a rubber orifice in the hole can anyone explain to me what this is for
il pump discharge tube is ~ 1/2 inch dia and has a threaded fitting going into block. Are you sure this is what you are referring to? Maybe the ! 1/4 inch tube feeding rocker arms?
.....as in yellow circle:
This post was edited by JMOR on 12/25/2023 at 08:01 am.
(quoted from post at 11:20:36 12/25/23)
Thanks guys I figured it out at one time someone didnt
put the pipe far enough into the block and the nut push
the rubber seal off and compressed it in the hole and it
formed like a orifice
