Oil pressure was low in my TO-30. So I did the easiest thing first which was to pull out the oil pump for a look-see. I haven't gauged the impeller-to-body clearance yet, but I did notice that there was no gasket between the plate with the six pan-head screws and the pump body. Somebody did rebuild the oil pump before (aluminum driving wheel and damaged slots in the pan-head screws).
No gasket - the inside of the cover is scored where the impeller gears were rubbing against the cover. I'd like to make a paper gasket, but after reading the archives, I got the idea that one MUST use the gasket supplied in the oil pump repair kit. My question is, WHY?
I know that one of the functions of the gasket is to provide clearance between the cover and the impeller gear thingees. How much clearance do I need and why can't or shouldn't I make my own gasket?
