Rebuilt engine, It had a rod bearing that turned. I had to replace the crankshaft,Now I cannot get the engine to oil,what i dont know is wheather or not the oil pump failure was the cause of the the rod bearing turn, it was a little low of oil. the pump looks good, can anyone tell me a litle bit about the rotery oil pump.
Did you prime the pump before installing it? I wouldn't run the engine until you take a look at the pump. It may have been the culprit that caused the rod failure. Set that pump in a clean container of engine oil and spin the drive gear by hand and see if any oil is being discharged.
It's a good idea to pressure lube the engine during the initial start with a pressure vessel.
You can use an electric fuel pump to pump oil into the oil gallery. Hal
