Oil seal needed for d17
If you can't get the info off the old seal, Do you have a parts book? If so find the seal number and there are sites on line where you can cross it, or most any vendor selling seals should be able to cross it. If you don't have a parts book, click this link https://apb.agcocorp.com/# . It will take you to the online parts book where you can find the one you need. You don't say which D17 you have and from the info you posted I'm not going to try guessing which seal you want, I might give you a number for a wrong one. And I just did some seals on a D14 and the replacements are only about half the thickness of the originals, don't be surprised if that happens.
most new seals are narrower than originals and if no number on the seal measure the shaft diameter and outside diameter of the seal and go by size. you can also double them up . but not necessary
