Schnautz
Looking for original equipment (oil seals) for Farmall M brake shaft. Preferably new/old stock if available. Where can I look? Does the M and the H share the same part number?
Different part. The number on the seal (or IH part number) is easily cross referenced with better seals from Chicago Rawhide, or National. The new seals are thinner, and two can be used. Pack grease between the seals to assure the outer one gets lube. Jim
