Oil Sending Unit 2444
I recently bought a 2444. The low oil light has been disconnected and I cannot find where the sending unit is. I think it should be by the starter and they have removed it and plugged the hole. Does anyone know where it is and what the part number is?
Hi, if I recall correctly the oil pressure sensor switch was screwed into the right side of the block above the oil filter. The hole in the left side of the block above the starter is the block drain.
SWITCH 392249R92
SWITCH ASSY., oil pressure, 424, 2424, 444, 2444 and 3444 tractors.
JimB
