Oil system ford 172 134
My problem is no oil reaching head or rocker assembly.
I request a picture of cut away engine, diagram or illustration showing oil path from oil pump to pan.
I have heard from other tractor groups but no straight answers of how oil system works.
If you have a shop manual with pictures please post them.
(quoted from post at 12:05:31 06/19/22) My problem is no oil reaching head or rocker assembly.
aybe these will help.
There is an O-ring at bottom of tube (white circle)
Oh that helps greatly. So it's a milled out spot on the cam. So all I need to do is roll engine over and hopefully line up hole and see if it clears itself.
(quoted from post at 08:33:32 06/20/22) Oh that helps greatly. So it's a milled out spot on the cam. So all I need to do is roll engine over and hopefully line up hole and see if it clears itself.
o milled out spot....read the words. "drilled holes".
Just four hours and 45 minutes ago 1Sarge got what he thought was a good answer to the very same question right here on YT right here on the Ford Forum.
