Absent Minded Farmer
What is this oil test of which everyone speaks? What does it test for? Is it to tell me there is something wrong with my engine or does it tell me if there's something wrong with the oil I'm using? Is there a test to tell me what kind of oil is in a machine? I bought a NH Stackliner & would like to know what the former owner was using. At the moment, I would just like to know what to use to top it off if it needs any. Currently, it doesn't. Don't know if that will change in the future when I use it more or not. Changing out the fluid would be rather time consuming & time is something I don't have a lot of at the moment. That machine seems to be all hydraulic lines, valves, cylinders & a pump.... a couple tires & a frame.
Thanks,
Mike
https://www.partsvu.com/blackstone-labaratories-oil-analysis-kit-engine-transmission-oil-testing.html
I've used them several times - to tell me the condition of an engine on a used vehicle I've bought.
They cant tell what brand of oil is in the test, that's been submitted, but they can tell the viscosity, and if there is high in something that will hurt your engine eventually, I send some in,thru Cat, do one test, it's a good experience, and you can call the lab technician and talk and ask him some questions!
I never did trust oil testing. I had a guy at a lab. Tell me buy the time the oil fails the test. It is too late for the engine.
The oil test is a method to monitor for unusual wear in an engine.
If there is a failure in process, it will shed metal into the oil. It also looks for coolant, excess fuel, anything that doesn't belong in the oil.
It's best done on a regular basis so you can keep a running tab on what's happening with the engine, look for an unusual rise in any contaminate.
Sounds like you are mostly concerned about hydraulics. With what hydraulic pumps and motors cost I would not run it without changing the hydraulic oil and filter. I paid $5300.00 for a new pump a few years ago. Not including labor.
Oil tests have saved me several engines. Ford tractors with thermostart, the heater will element will sometimes fail in a way that leaks fuel into the crankcase. Ive used both Napa, Southern States, and Cat for testing. Right handy trouble shooting final drives and transmissions to. Sometimes its cheaper to repair, sometimes run to destruction and replace. Knowing whats wearing abnormally may get another 500 hours out of something.
There is what your lab guy told you, Billy, and there is actual experience we have had engines saved by oil testing. One test should an increase in silica a sign of air filtration failure, we found a small perferation in an air intake hose, which we repaired. Another tractors oil tested showed traces of antifreeze, we definitely have had engines saved by oil testing.
(quoted from post at 21:34:30 06/29/20) I never did trust oil testing. I had a guy at a lab. Tell me buy the time the oil fails the test. It is too late for the engine.
Billy, when one is getting oil tested regularly he gets reports that show trends waaaaaay before it shows failure, so one takes action waaaay before there is significant damage.
I don't believe that, i know a couple of cases where a 3208 Cat bearings where going out,they called the customer and told them to shut it down now!!
Hello Absent Minded Farmer,
YES it works. While at Mobil I took those samples for rears: transmissions, and engines.
Mobil called them EMPA samples. Engine Management through Preventing Analysis.
All possible contaminants were counted in PPM or part per million,
Guido..
Testing after failure or problem develops,,,, will do no good.
Testing on a routine schedule will save an engine only if you stop using it and fix it,, when it shows a problem.
If you have no intention of fixing it, dont bother to test.
Testing on a purchase with out know how many hours are on the oil, may not correctly tell you the condition of the engine.
Testing a $3000 purchase is probably not worth it. A good walk around would show as much... Testing a $50,000 purchase probably worth every penny.
Either or. The hydraulics on the bale wagon was an example of something not engine related. Didn't know if that could also get tested. I'll definitely
change out the oil this fall when I get more time & figure out how to squeeze the old oil out of those long hydraulic cylinders. Only have a few acres
to work with at this time so I'm not too concerned.
$5300 for a new pump? OUCH! The Cessna pump I would need isn't half that, but I still would rather not spend on it & risk getting metal shavings in
the system at the same time.
Mike
The Army went to oil testing way back in the late 70's. A good lab can tell you what the condition of the oil is and if there is contaminates in it. They can tell if upper or lower engine failure is emanate. It doesn't stop an engine from failing. If you ignore the lab and continue running it it will blow eventually. What they can do with oil testing is A: tell you when an oil change is needed. We use to have to change the oil in the M60 tanks, 17 gallons, every 6 months or 100 hours. That's a lot of oil. With testing that was stretched to once every couple of years. They would also come in and say swap that engine or transmission out now. Failures in the field dropped to almost zero and catastrophic failures were a thing of the past. If you can catch it before it windows a block you have rebuildable materials. If you window it you may have just bought another engine. Not only do they look at the they look at any metal found and determine if its from upper or lower wear. They may come back and say change oil and filter to change oil and filter and run X minute and resample or tell you to repair/change the component tested.
Rick
Until I posted this question, I had no idea what could be figured out from an oil test. It really is interesting. Especially at the component level.
With my luck, I'd send in a sample & just get a note back asking, "Why do you run this junk?". Lol!
Mike
Does Cat test non Cat fluids? I just started poking around on their site & can't seem to find that info. As for the viscosity of hydraulic fluid, isn't it all roughly 10W? The manual has that listed if you can't find what they recommend. Think Hy-Tran was interchangeable with 10W also.
Mike
Yes. For engines the test would ID many metals from zink to copper to lead. Plus coolant contaminants such as borom for one,
Chrome found in the sample would come from rings camshaft rollers.
You can prevent a failure by comparing PPM count each sample.
PPM count was a given standard for each component tested,
Guido.
Way to many variable to say when its time. The EMPA sampling will allow longer drain intervals.
The Mobil fleet was changed over to Delvac1 15w40 and oil drain interval was @ 100.000
miles, oil sampling every 10.000 miles, and fuel and oil filters were changed @20..000 miles,
Guido.
