Oil viscosity
SVcummins
What do these numbers mean in weight like engine oil
My numbers are 73 w 190 and I'm running very slow.
73 years old and 190 #. lol
I felt better when I was 20w120.
Just keep in mind that while Deere has kept the same J20C name over the years, the actual spec has changed. 1975 Hygard was not the same as what you get today. The older oil was about 20w. The advent of IVT drives forced them to go to the multi grade oil used today.
I have not come across a farm store brand J20C equivalent yet that is the thicker multi grade.
(quoted from post at 11:22:51 03/25/22) Look at the viscosity chart.
Read across, it will give you an idea what to compare it with.
Note the huge difference in the numbers between SAE crankcase oil and SAE gear oil!
Viscosity Chart
This is why I tell people to use sae 50 or sae 60 for transmission gear oil when they can not find GL-1 sae 90.
Safe for wet clutches and copper based components .
The typical response however is a blank look in reply .
Sae 50 was used for years in manual heavy truck
transmissions. Unfortunately it is harder to find here than
GL1.
I have some tractors that call for Sae 50 in the
transmission.
