(quoted from post at 07:09:03 10/22/19) I heard that a mix of trans oil and acetone is one of the best rusted frozen nut and bolt combo to use on them. I was thinking of trying it what you guys think of this or what works good for you. My brother in law says that he uses Kroil oil and that works the best. ? Thanks.
So, crazy idea, don't try this at home, but I'm going to express my curiosity anyway.
What about dairy milkstone remover (which is an acid) first?. I've found that this is a fantastic rust remover. It literally etches it away.
I've never seen anybody suggesting a few drops of this to etch rust first, letting things sit for a while and then trying heat and/or penetrating oil, so maybe there is an issue with...what?
reacting with the penetrating oil?
etching away metal with the rust?
corrosive residuals?
Not sure.
All I know is that I soaked some parts that were rusted together in dairy milkstone remover to get rid of the rust before restoration. It got rid of the rust, and the parts just fell apart. I didn't have to beat on them or heat them. Granted, these weren't threaded parts, like bolts and nuts, it was a clamp over a piece of thick metal rod.
I only mention this, because there are some places that are too close to wiring, rubber booted parts or other things to use very much heat on, especially enough to get a part cherry red.
In those cases, after a couple of bouts of trying various penetrating oils/ATF, etc. I ended up just breaking the bolt/nut off and having to drill and re-tap. If I had to do it again, after my experience with milkstone remover as an actual rust dissolver, I would be tempted to use a syringe to surgically dose the part with some and give it a while to dissolve some rust away before trying any kind of penetrating oil.
For parts that can tolerate heat, just like others have said.... get out the acetylene wrench and make it cherry red, and then use wax on it as it cools (for bolts) or try to remove when still hot (for nuts).
