Old Brush hog identity
farmdave
Can anyone help me identify this rotary cutter (bush hog, brush hog)? It's obviously a pull type with a crank height adjustment. I need a replacement bearing and I have no idea where to look for one. I can send more pics if necessary.
Thanks!
I figured that would be the case...it's like finding a needle in a haystack identifying one of those old implements.
Thanks for the input.
My guess is a Servis Brand Brush Cutter. I have a 10 ft version and the wheel/axel configuration is almost identical.
Hi Sam,
I think you're correct. I reviewed a bunch of old Servis brand rotary mowers online and there were some that were very similar to mine. Fortunately, I found a local shop that will replace the bearing on the driveline configuration. Thanks for your input!
Good deal! I know that mine is so overbuilt, This is this past spring when I was painting it before I put the gear towers back on.
that I will never have to replace it!
