I have a 1974 Cat D5 that has developed a problem with the right steering brake. I have the original manuals and have tried adjusting exactly as described in the manual but even though I have tried it multiple times it does not help. The D5 has access panels behind the seat and on the rear of the case. I can see the brake adjustment nut and the threads. The left brake which works fine has about an inch of adjustment thread left. The right one which is not working is tightened almost all the way down with no threads showing. I can get the right brake to work for a short time by tightening the adjustment nut but it doesn't work for long. The brake material on the band is about 3/8 of an inch thick on both the left and right brake shoes so they are not worn out. A friend who works in the industry said sometimes the pin that goes through the eyes on the end of the break shoes will break and then you cannot adjust the breaks no matter what you do. Sounds like it might be my problem. Can the brakes be repaired via the access panels or will the right side tracks and the housings have to be taken off to work on this? I am not a mechanic so I could use some advice. Looks like an expensive repair if the right side has to be disassembled.
