Howard H.
I was working on refurbishing an old Delta/Rockwell drill press I picked up for nothing at an auction with a bad motor. I found an old Dayton 1 1/2 hp electric motor out in the barn. It is a dual voltage - 230 or 120 motor.
It may be 10 years old or 25, and I don't know the history on it, but when I hooked it up, it spun free and easy, so I mounted it on my drill press.
The rotation was wrong, so I reversed the leads per the label on the motor of the 120 volt wiring diagram, and it corrected the rotation as indicated...
I used it several times - and was quite pleased with myself, until I was drilling on something long and metal - and the end of my workpiece hit the frame of the barn and instantly blew a big arc - and blew the circuit breaker.
In checking more carefully, the entire drill press is energized at full voltage while it is turned on. There is no voltage while the power switch is off.
I guess by wearing rubber sole shoes, I wasn't shocked.
I thought at first, I must have mis-wired it, but in double checking everything, it is correct per the label diagram and per the lead numbering. The wires to the capacitors look fine - and clean - and capacitors look fine as well. I don't have any shorts up until the point the power wires go into the motor.
My questions are:
Is it possible for the motor to be bad in a way that it can energize the drill press frame - while still working fine in terms of spinning under power?
How could I test the leads to determine an internal short of the motor?
Does the fact that it is energized while on mean that the barn grounding is faulty? I wired in a heavy three-wire power cord and 3 prong plug-in to the drill press and the ground wire is bolted firmly to the ground point. But Dad had the barn built probably 50 years ago when I was a kid, so even though all the barn wiring is professionally installed in metal conduit, etc, it is pretty old.
Thanks for any advice,
Howard
My questions are:
Howard
