pictures.I'm looking at 2 old tractors they are shaped like Fords but they are one row with seat off set to the left. Any one know what they could be?
That's quite a mystery. I can't think of any one row tractors with seat offset to the left. Farmall, Oliver, and Ford all had seat offset to the right. Allis, Massey, and Deere had seat pretty much, but not always, centered. Did Moline or Case ever offer a one row tractor, offset or otherwise? And frankly, only Ford's one row looked like a Ford (utility style). Maybe an import or custom built?I'm looking at 2 old tractors they are shaped like Fords but they are one row with seat off set to the left. Any one know what they could be?
Agree. If it is a high clearance, offset Ford it is most likely a 501.
So, how do you reconcile his claim of seat offset to left with the 501's seat offset to right? Frankly, I think the likelihood that you are correct is very high and that OP misspoke about the offset. Conventional moldboard plowing would be very difficult with the lh offset. Pictures will be very enlightening.Agree. If it is a high clearance, offset Ford it is most likely a 501.
Production began in 1958 or 59.
Built on the 601 platform
Not a common model but not rare either. Officially ended in 1962 but it was popular enough in the vegetable industry that Ford continued to build them by special order into the 1970s - well after the big switcharoo to the 3 cylinder tractors in 1965.
Ford also sold an offset built by Shibura in Japan. It was the 1710 model
Good point.So, how do you reconcile his claim of seat offset to left with the 501's seat offset to right? Frankly, I think the likelihood that you are correct is very high and that OP misspoke about the offset. Conventional moldboard plowing would be very difficult with the lh offset. Pictures will be very enlightening.
It all depends on which end of the tractor he was looking at.So, how do you reconcile his claim of seat offset to left with the 501's seat offset to right? Frankly, I think the likelihood that you are correct is very high and that OP misspoke about the offset. Conventional moldboard plowing would be very difficult with the lh offset. Pictures will be very enlightening.
If the OP had ever been a sailor he would have said the tractor was offset to Port and it wouldn't have mattered which end he was looking at.It all depends on which end of the tractor he was looking at.
