Apparently for a few years before my father died, instead of fixing his chain saws he just bought new ones. I have 4 old saws I'm trying to resurrect so I can have a backup to my main saw. I started working on an old (probably 20 years or so) Homelite 18" saw but I can't get a spark no matter what I do. I've tried a new plug and even a new coil. I set the distance from the coil to flywheel with a business card like I've always done before, made sure I got good connections but even with a new coil I still don't get a spark. I've checked/cleaned the coil mounts and ground screws and tried unplugging the ground wire that goes over to the kill switch. The ignition on these things only has a couple of parts so there can't be too much wrong - or that's what I'm telling myself. The magnet in the flywheel is fine and the saw really doesn't look like it has much use on it. I've got continuity on the plug wire to the coil. Do you guys have any ideas of what else I can check?
Thanks,
Kerry in NE TX.
Thanks,
Kerry in NE TX.
