Old Model A John Deere tractor
RoboRN18
We have drained the oil and transmission
fluid on our old Model A and looking to
replace it. I have been advised to use a
SAE 30 oil, but I've not any advice on
what kind of transmission fluid to use.
Any suggestions?
Those old engines were not very fussy about engine oil, but
a good diesel-rated 15W-40 will give you the best modern solution.
for the gear cases, 85-140 would be my choice. You want a lube that
is safe for "yellow metal" to preserve bushings and other brass/bronze parts.
Never heard of diesel when I had my2 cylinder models. the 85-140 is good choice but never used anything but plain old 10-40 oil, what I would be using if I still had them. Some of them the older models the book called for 50 weight oil but that is too heavy and not needed.And tis was the heavy field work. 38A, 46B, 49B, 50AR & 51A. Wish I still had them.
It really doesn't matter what you use for engine oil. Back in the fifties and sixties and into the seventies when the two bangers on this farm were used heavy dad used 30 weight non detergent and flushed out the crankcase with kerosene once a year. When multi grade oil came in those same two bangers had 10W-30 poured into the crankcase and they ran just as long between overhauls. I don't know if oil consumption was the same or not. Today I still have those same tractors but I have changed them over to 15-40 merely because 15-40 is in the big tractors and that is what I have in bulk.
A friend of mine told me when he was a kid a tight wad neighbor of theirs would come over to get their used oil to use in his unstyled A when he did oil changes. He drained the oil out of his gas A and poured in used diesel oil thinking he was doing the tractor good by changing the oil! My friend said the old A was loose as can be and leaked pretty bad but it kept on running in the field under load all day with that used oil in the crankcase.
