Old tyler fertilizer spreader
Does anyone have a source for an axel for a 1988 Tyler F45 fertilizer spreader? I tried Jenner Sales which is a parts supplier for Tyler with no luck and also our local trailer supply store. The trailer supply store can get one but it is about 8" wider so the small drive tire won't land. Does anyone have another source for the correct one?
A long shot. Back in that time frame several pull type fert spreader makers used a Henschen 45 degree axle. Seems like there were also
some Henschen zero degree used. Good luck
I just go to my local independently owned auto parts store and pick up a sheet of paper where I fill in all the dimensions, give it back and in about four days I have my axle. Not expensive either.
Take your measurements and call these guys,if they can help, they will fix you up.(they rebuild a lot of trade in stuff on site)
Doyle
The back one broke last fall and was replaced with the one from the trailer supply store and was wider which didn't matter on the back. Was just gonna replace the front one before it broke too.
Can you get the wider axle and then lengthen the axle on the drive wheel? That turns so very slow that nothing needs to be precision.
Just get an eight or six bolt hub abd axle from shoup then weld it in a piece of square tubing for the right length axle. could get enough tube for both in one stick and cut to fit. Then bolt your springs to it for the suspension. I have not replaced the axles yet but changed the cross member in the frame a while back.
