Oliver 129 Mower Conditioner
UP Oliver
Hello.
I need a bearing for the roller on my Oliver 129. It is an old machine, I know it is basically the same machine as an Owatonna (not sure the model) and a Ford 536.
Any idea where that can be found? I heard it is a standard bearing, so if that is the case I should be able to find it once I get it out and measured. Right now I am having fun with the gib key.
Any knowledge on the topic would be appreciated.
Thanks.
Check out this page, if it's #3, it's NH part number MC01010103. https://www.mycnhstore.com/us/en/ne...56875BD6/76ED724F-E6BE-E111-9FCE-005056875BD6
Your mower should be the same as the Owatonna 196,206,216, according to one of your previous threads about the mower from 2013.
Do you have the bearing out? I'd just pull it and get the numbers off it. I can't imagine it would be a generic and not marked. It's probably a regular Timken or otherwise numbered bearing.
Thanks for your reply.
I don't have it out yet, still trying to get the gib key out. I think I need part number 17 in that diagram, but it is the bearing on the other side of the roller. I have the manual for an Oliver 129 and the diagram in my manual is almost exactly the same as what you posted, but the part is number 20 in my manual. The part number is 525662-E, "bearing 1 5/8" with collar." I can't seem to find that anywhere online. I do look forward to getting it off the machine and seeing if there is a number on it.
Would you have a part number for 17 in your diagram?
Thanks again.
Actually, I think I found it using the part number you sent me. I see a MC01017871. I clicked on it and it sent me to Amazon for something not even close. I will look around. Any help is appreciated.
Thanks.
