I went all the way to the u joints. The end of the axle got a little worn because the bushing was cooked. I could not get the axle out so I split the u joint and had it turned and a bushing made. Got the u joint back together and it's like new back to the u joints. I need to do the other side and if the axle could come out man it would make the job easier. Really hoping someone chimes in.I'm with you on the confusion. The section on the axles shows two snap rings, but they appear to hold the bearings in. Do you have those out? I went to differential too in the parts book. That doesn't show anything in the way of snap rings or anything either. I've had both planetaries off mine, but never went any deeper than that.
Too bad Mitch isn't on here, he's been all the way in to his.
I think I have we a service manual lying around somewhere. If I have the time and find it, I'll scan the pages. Your manual should be available from Floyd county museum as well.That is why I stopped were I did. It kept taking me deeper and deeper. I stopped at the u joints. The knuckle was filled with all sorts of stuff. But everything looks tight. I am putting it away for the winter and will continue next summer. Hoping to get her back to her glory. I am getting a little at a time and learning a lot as I go. Wish Mitch would come back around.
That would be very nice to have. I wonder if it's different from the one I have.I think I have we a service manual lying around somewhere. If I have the time and find it, I'll scan the pages. Your manual should be available from Floyd county museum as well.
What do you have?
What do you have?
