Oliver 1365 - Hydraulics Slow
CreekBottom
My Oliver 1365 seems to be lacking good hydraulic pressure. I did find this past year I was low on fluid so I filled the reservoir up, but when I started using hydraulics I had oil flowing out of a small "cap" in front of the seat and to the right. Just wondering if this is a bad pressure relief valve, or if it may be another issue. Thanks for any help!
Mainly I think there is a pressure issue due to the 3 point barely being able to lift anything or even hold it up. I even took a small disk that my Ford 8N lifts no problem, and the Oliver had a hard time lifting it.
(quoted from post at 11:29:45 02/16/18) What reservoir did you fill up? The hydraulic pump gets its oil from the rearend/trans and you check it with the dip stick beside the parking brake.
I filled the reservoir that sits next to your left foot/leg.
The fill hole is just ahead and to the left of the shift. If it gets worse,could very well be a worn pump. Mine did that this past spring. When I started moving round bales off the field,I could get 15-20 bales before it got so weak it wouldn't even lift the spear anymore.
I got a new pump from Rick Stair at Ricks ag parts dot com. The pump,drive hub,gasket and O-rings with shipping was under $200.
There is also a strainer between the reservoir and the pump. Make sure that screen is clean. Do you have a gauge to check the pressure?
