Oliver 1365 Parts
Iniles
Good evening I am looking for a Front Planetary cover for an Oliver 1365. I think this could also be the same as a white 1370. This is for a 4x4 the cover holds 3 planetary Grears. Let me know what you have.
If you're desperate and don't mind spending money, you might try New Holland. Rick Stair at Ricksagparts can get seals.
I believe that cover was used across multiple models and makes. You could try contacting importtractorparts.net and see what they say.
Not quit the answer you were looking for. But when the diff cover got smashed up on our Kubota and I couldn't find a new one, I made one without too much trouble. Base plate cut on our plasma table at work to be the right profile with the right bolt-hole pattern. Got a thin flat bar (2" wide or so) to make the wall that extends out - tack it in one spot, bent it to match the inside profile half an inch away or so, tack again, repeat, then use the centre piece that was cut from the base-plate as a cap on the outside. Took an hour or two to make, but worked perfectly and probably cost me $20 in parts. I'm pretty lucky, however, as we have a plasma table at work and I cand draw stuff up in CAD. So might cost you a little more.
