Hello. I own a mid-1970"s Oliver diesel model 1365. The good: the engine runs great; drive train and mechanical subsystems appear to be sound, if the meter is accurate (it does work _now_), it has just under 2500 hours. Bad: the sheet metal is very rough and rusty. I am trying to put this tractor in good enough working condition to be suitable for doing general property maintenance on some raw land I have in Virginia. I have a 30" rear rim with rust around the valve stem hole, to the point that the valve stem cocked over the winter and the rusty edge poked a hole in the tube. My plan is to remove the rim, and if possible have a patch welded over the existing stem hole, and drill another hole on the opposite side of the rim (even if I decide that the rim is too far gone once I get it apart, I"ll need to do all of the following to replace it.) I have auto mechanical experience from years ago, but I am a tractor neophyte. I bought all the available reprint manuals for this tractor, but some items are not covered, probably on the premise that anyone who uses a tractor must already know about them. Unfortunately, I do not. I don"t have a clue about the most basic item of all - what is a safe jacking point to pull a rear rim on this tractor? I don"t see any obvious point that looks sufficiently strong to hold the weight that I could latch onto with a farm jack. I certainly don"t want this beast falling over on me or landing on my foot. Can I use a farm jack for this, and if so, where do I put it? Next, it appears to me that the rim is separate from the hub and designed to be removed (along with the tire) by a set of five nuts and clamps. Is that the case, and (once the tractor is safely jacked and supported) do I just remove those bolts and clamps and pull the rim straight out, or is there more involved? Finally, once I get the rim off, I anticipate that I can use ordinary pry bars, hammers, and other hand tools to remove the tire. I have done tire work and I"m fairly confident that I can handle this part with little trouble, but if there are any non-obvious tricks, I"d sure like to know what they are. I really appreciate any guidance that you can give me in this task. Thanks in advance.
-Sam
-Sam
