Oliver 1550 radiator
super99
I posted the other day about the short fill neck on the new aftermarket radiator on my 1550. I looked closer at it today, looks like it is bent down around the filter neck. Any chance of reaching inside and bending it back up where it belongs without cracking the solder joint?
yes it is dented in at the filler. i would put the cap on and make something like a plate with a u in it to slide under the cap and give it the slide hammer effect with the top plate to stop on some rig up, like a couple 2x4's screwed to the plate . or just flip it upside down and stand on the plate and pull up on the rad till its out. that stuff is not that tough. and if it was mounted on the tractor u could slide the plate under the cap and if you cant pull it up by hand weld an eye on the plate and use a chain hoist to carefully lift it.
Cut a piece of at least 1/8 flat stock that will fit down the neck, but longer than the hole is round. Drill a hole in the center of the piece that will take at least a 5/16 bolt. Make the bolt hole bigger than the bolt so you can cock it sideways to fish the works into the radiator. Make a brace that will push off something solid, like the radiator tank edges or the support (if its in the tractor yet). Run your bolt up through a hole in the brace, washer and nut it and slowly pull the top back to where it belongs. If the solder does crack, slowly apply your propane torch to it and it will flow back to uncracked. If you try to pull up on just the top of the neck, you WILL crack the solder.
What steeve said but put a heavy piece on the bolt to use like a slide hammer. Or you could unsolder the tank, bump it out from the inside and replace it. Maybe do that at a radiator shop if you can find one.
Just get a hook of some kind in there and pull it up. I dinged the one down in my 4040 Deere one time and was able to lift it up.
I don't know except that I'd wire brush it real good so it is clean if you do have to do some solder work. I'd try a steady pressure pull before resorting to hammer pulling.
