Oliver 1550
We have recently purchased an Oliver 1550. Im curious how much work needs to be done to have a 5.9. Cummings fit into this frame. Is this even possible or have I fell off my Rocker??? Any info is Greatly Appreciated .......Happy New Year everyone :)
You're off your rocker. That is the old spur gear transmission like the 770 had in it and the rear end isn't much heavier either. You'll blow the whole thing right in half. They were a great little tractor and well worth overhauling the original motor if nothing's broken on it.
It is a nice little Tractor. But we have a problem with just leaving things the way they are sometimes. Thank You for your response :)
I agree with rrlund, your off your rocker. Sell that tractor and buy a 17xx and up series tractor with a bad engine and put the Cummins in that.
Is this for farm use or puller? For using on the farm and need more hp, I would put a 310 diesel with fresh upgrades to bearings and wrist pins....have it balanced....would be good on farm and could turn some heads at farm stock pulls
Yeah were going to pull with it :)
Is the 310 the most powerful motor to run in it? We have a 310 in the shop and I have no problems adding to our 1550. I wanna push it to the limits tho :)
Thanks Again
diesel or gas? I would go with a 310 gas, bore w/new sleeves 4.25 and offset grind crank, I am building a 425 ci, for my 88, You will have to shorten the drive shaft, make some room for radiator, I just missed a 1555 I wanted to use around farm. good luck! 8)
