Sidewinder
I have a 1600 diesel that used to when started cold the oil light would turn off immediately and when turn it off hot it would take a few seconds for the light to come on. Now the oil light has been slow to turn off when started cold and quick to turn off when shutting it down but never came on while operating. But the other day light came on. Turned out the sending unit was bad. I replaced it with a universal one and started it up and after a couple minutes the light came on at idle. I bench tested the sender and it switches off at 22 psi. I read somewhere that this motor "Waukesha" has low oil pressure to begin with. So I started back up at 3/4 throttle and the light would flicker I shut it down. I figure it should at least have 22 psi at 3000 rpms. Pulled pan and looked at all rod bearing and all look good. Not sure about main caps as they look hard to torque. Digging further I find there is an oil pressure regulator but where the diagram shows it my engine doesn't have that. Where should I be looking?
Thanks Greg :?:
Thanks Greg :?:
