Oliver 1600 gas
My tractor keeps cutting out like its out of gas. I had to run it with the choke wide open to keep it running. The sediment bulb was clear and so was the screen. Is there a screen inside the gas tank? I"m going to let the tank drain out and look inside to see if there is any junk in the tank. Anything else I should try? Thanks
as a last resort check your intake manifold for cracks and where it seals to the head.the neighbor's 550 did the same thing and it ended up that it would suck in air through the leak and lean it out then quit.it would run at 1/2 choke.hope this helps
