Oliver 1650 Hydraulic Issue
rlyonmad
I have an Oliver 1650. Was using a single acting hydraulic cylinder and it extended out and would not come back in. I tried the tractor on a dual cylinder and it would not move the cylinder in or out. It is filled almost to the top of the fill line on the dip stick, the hydraulics were working with the dual cylinder while I planted corn two days before. Currently hydraulics do not work at all. hoses wiggle like it is pushing oil but nothing happens. was wondering if an air lock, according to user manual there is an adjustment screw on right side of seat all the way back by the PTO lever turned it out as far as it would go which wasn't very far re-tighter the nut for it and still nothing. There is another adjustment screw on the same side (the right) that is set in under the seat looks identical. was I suppose to turn that one in or is there something else I should try? thanks in advance, Roger
Single acting cylinder needs a load to push it back. For single acting you must back out the bleed screw three turns, NOT ALL THE WAY, and lock the nut. It's the one at the top of the housing just under the seat. Then back out the bypass valve screw a few turns. Again, not all the way out or the fluid will gush. It's the one on the right side down by the platform. Both have a sealing nut, tighten them to lock the settings. For double acting turn the bleed screw IN. The bypass valve disables the three point lift.
