I picked up a project 1968 Oliver 1650 gas model that is in good shape. Stored inside. So far, we've put a distributor, cap rotor, wires, and plugs on it. Still cleaning the fuel tank, it starts, runs excellent! Now in the process of getting all the old hydraulic fluid out, without a drain plug, it has to be pumped out. Hyd filter was missing, so we put one in, hydraulics were sluggish at best, with lots of nasty garbage coming out with yet another hyd oil change. Questions I have.
OK to continue to use Universal Hyd oil, or is there a better option?
Motor oil I have 15w40 diesel oil by the drum, OK to use this or stick with a 10w30?
Hydrapower unit stinks like gear oil, will replace with dextron III according to manual.
Rear oil a little milky, recommendation? 85w90?
thank you in advance for the advice offered up!
BTW I intend yo use this tractor this summer to mow hay with.
