I am no mechanic but my Oliver keeps me learning. I had the cylinder head on my 1750 overhauled and while I was putting it back together, installed new injectors. It runs great, no more blue smoke and seems to start better (will have to wait for cold weather to know for sure). But, now it is wet stacking. I checked the fuel pump timing and it is right on the money. Four degrees before TDC. I also pulled the exhaust manifold and all 6 cylinders seem to have about the same amount of fuel/soot...so I don't THINK it is one or two of the injectors.
By the way, this will always be a light-duty tractor so there will be little heavy duty pulling or PTO work.
Reading these posts, it isn't clear to me if "working it hard for a few hours" might cure the problem (seat the valves maybe?) or just be a temporary fix until the fuel/soot mixture needs to be burned off again?
I see one comment indicating running it at PTO RPM for a couple of hours might be a substitute for "working it hard". Opinions on that?
Finally, is there a way to turn down the fuel pump (reduce the horsepower) to solve wet stacking in a tractor that will be light-duty most of the time?
Thank you for reading my post.
