Oliver 1755 clutch issues
boatmanjj24
Ok reaching out for some help. This winter I put a new clutch, pilot baring,throw out bearing,seals the whole works into a 1755 it was perfect snappy clutch hi lo and direct was snappy. Now 5 hrs on a mower and you let out on the clutch and it would grab slowly and then take off did it in direct and over and under stomped on the break and slowly loaded the tractor side not kill it. Made sure the clutch adjustment was right now there is no movement at all. I'm at a loss what's up with this 1755??? No clutch smell like slipping clutch nothing. Clutch fingers were set properly the whole work. Could we be seeing some kind of issue in the over under now??? Could there be some kind of failure in the clutch?? What kind of trouble shooting can I do to narrow this down??? Can I do some pressure checks on the the over under if so what kind of pressure should I see?? Any help would be greatly appreciated thank you.
There are pressure checks on the O/U that can be made. Assume you do not have a manual, or you would not be asking. Suggest to go Agco site and order one, not that exspensive to buy the download version. I looked at my manual and it would be quite a few pages to post on here.
I would post this in the Oliver section on this site. What oil did you put in that O/U when you put it back together?
This link should take you to the manuals.
If i were you, i would down load the 2nd one listed and then the center one. Its easy to do.
http://www.agcopubs.com/default.aspx?model=1755&brand=44134&keywords=tractor&searchForm=0
