Oliver 1755 PTO slipping
Found out last night that the PTO slips on the 1755, how about some pointers on the best way to determine the exact cause of the slippage, or should I just pull the unit and inspect it right off the bat?
Fisrt of all,have you checked the hydraulic oil and the rear diff fluid levels? If the rear diff is over full and the hydraulic is low,an internal piston seal is bad.
Next,inspect the mechanical linkage rod pivots for wear. Disconnect the linkage and engage at control unit and see if it stays engaged.
There are pressures to check also,but try this stuff first.
The PTO clutches don"t take much and they"re fried,so good luck!
We had a few 55 series tractors over the years.
Don't torture yourself any more. Just
drain the oil and take out the pto unit.
The clutches are fried if it has done
quite a bit of hard work.
