Oliver 1955 3 point
I"ve been working a few of the bugs out of this rascal.... The 3 point seems to be a bit of an issue. It"ll raise and stay raised. I unhooked the line from the cylinder to let it bleed down. Then hooked it up started the tractor with the lever in the down position.... The 3 pt. went up....So I"m guessing I need to pull the cover under the seat. What should I look for? The tractors been sitting a couple of years but the guy used the three point before parking it....
could be a busted roll pin under the seat.take the very top cover off the hyd unit check the linkage out real good. our 1755 did that same thing it was a sheared roll pin
