oliver 2 row planter
Here are a couple of pictures
It is either a 202 or a 252. The cylinder does not lift the planter electrically. It is a regular old style Oliver 3 inch hydralectric cylinder.
I wouldn't really call those disc openers. I think that's more of a lister planter. You must be in the west where it's dry.
Why does the cylinder hook up to 12v if regular hydraulic.Do you think it's an oliver?Is there anywhere that rebuilds those cylinders and is there a market for these planters and apx value
It was called the hydra-lectric system if I remember correctly. the electric system was to set a sliding disc on the cylinder to make a consistent depth every time you lowered the planter. It was used at least as far back as our 88. It worked well for consistent plowing depth.
