Oliver 2150
rrlund
Is there anything inherently or chronically wrong with a 2150 that would make it a problem to use for tillage or chopping in this day and age? Just thinking it might do the same job as my 2-135 White.
Only problem would be engine wise if the American Bosch model PSJ injection pump is still on it. If it's been updated to the model 100 pump like most have around here that would be best as PSJ parts are pretty much not available.
Clark front axle. Was able to get all the parts I needed (new CV axle, sun gear, bearings and seals) from the local Clark dealer. If you can, try to find one that doesn't need those parts replaced, trust me! Not a lick of trouble since.
Takes 40 acres to turn it around.
The tag will say model 100. I would say like diesel tech said they have been updated to a model 100. All we sold were 2 wheel drive, but there was an early 2150 Cockshuut (via Yoder & Frey0 and a 4-144 industrial from the same place. Two rare 2150's I worked on.
Randy,
We have a 2050 with a turbo on it. This was our big tractor for 20 years farming between 800 and a 1000 acres. It has been a decent tractor but I am sure you know some of the issues they had with the engine. Check the front crank pulley and balancer to make sure it has not come loose. The old style damper was somewhat prone to crack at the key way and mess up the nose of the crank. The high oil pressure relief in the engine was not large enough and at cold starts they would build high oil pressure and cause the main oil feed to the heads to start seeping at the head gaskets. There was a bulletin to fix that. The wood block clamps on the injector lines will vibrate loose and destroy the injector lines. The lines have been discontinued. I have been into three of them in recent years and all of them have had either a badly damaged ring gear or pinion in the rear end. Those gear sets are getting tough to find. I finally found a new set for ours about 10 years ago after putting two used sets in it. It is a nice driving tractor but the hydraulics are not near as nice as the 2-135. Cabs are no comparison. No diff lock on the 2150. We still use it on a harrow or disc in the summer but we replaced it with a 2-155 about 20 years ago to do the heavy work. I would not want it as our main tillage tractor anymore just because parts are getting tough to get in a timely manner if it breaks down. I do not want to scare you away though. It would be a great backup for the 2-135. Except for the combines and four wheel drive we are like you and still do everything with Olivers and two older Whites.
I'm still waiting for details on one. Somebody called the wife this morning,asked if I was interested in it. Said he found one owned by an old guy who bought it new. His health is failing,wants to see it go to a good home before he leaves this Earth. From what he told the wife,he knows there aren't many of them around. It isn't cheap,so either he's dreaming or it's pretty decent. From what she's got wrote down here,it says 2150 "light row crop" front wheel assist,comes with 5 bottom plow. The guy who called was supposed to stop tonight with the contact information for the guy,but he hasn't shown up.
I don't know,we'll see what happens.
If it is a "light" one it probably does not have the planetaries on the rear. Our 2050 is twd with the planetary rear. It would be a good addition to your collection.
Not sure what your definition of cheap is, but there was a fwa open station one for sale by me a few years back that they wanted around 10k for. Looked like a good original, but never drove it. Wanted it in the worst way just because I like those old tanks. Wife about chewed my head off so I didn't pursue it. Was for sale for a few weeks then gone.
Does your 135 "wander" on the road? My cousins 135 does a lot. They had it fixed years ago and he said it worked well for a while but has gotten bad again. Gets to be a challenge with pulling full loads of corn lol.
It will is the toe gets the least little bit off. I put new tie rod ends on it a few years ago and got it set just right and it's OK. You want a steady hand though. Turn it the least little bit at high speed and it'll about put you right in to a panic.
