My 2255 has the 3150 engine and it started making a knocking noise. I can loosing the injector line and knock goes away. I figured I had a fuel knock at best or a bearing issue. I have changed the injector on the cylinder that's making noise but noise is still present. I had put the tractor in barn until I could get to it but had to use it today. Drove the tractor about 4 miles. On the way back home the noise went away. When I got home I cut it off to give my hearing a break. When I started the tractor back the noise was still gone. As I put the tractor under barn noise returned. The tractor has 55 psi of oil pressure cold and about 40 psi hot very little smoke if any and starts soon as you hit the key. Only thing I have seen is a fuel leak at the fuel solenoid switch but I thought this should be common to the whole fuel system not one cylinder. Has anyone had a similar issue before.
