OLIVER 252 DISK BEARINGS
Good morning, I have a Oliver 252 disk that the disk bearings are BAD!! Needless to say when I looked it over this spring before planting and I noticed there was play in the gangs I should have replaced them then but Hindsight is 20/20. I need to replace all of the bearings because I'm sure there either original or on their way out. Is there a parts page I can look at to get the part number of the bearing needed? I use Meesicks for all my new holland implements but was interested if there was a page like it for Oliver implements. If someone has the part number for the bearings that would be helpful too. Thank you in advance.
NTN Bearings has a great 'Bearing Finder' website. You have to know a bit about bearings to navigate it, but you can find almost everything you need there. In your case for instance, knowing that they were deep-groove ag ball bearings, 1-3/16" ID, 3.149" O.D., spherical OD, etc., you can find it as NTN #DS208TT7. Any local bearing or industrial supply should be able to order from NTN, and can also likely cross-reference other equivalents. And the NTN ones are probably both cheaper and better quality than the ones from Agco (the last bearings I got from Agco for a Massey baler were a very cheap offshore brand. NTN is also offshore, but a very good-quality and reputable bearing).
