Oliver 310 crankshaft.
dweaver
Hello,
I am working on an Oliver 1750 and have found that I have a large crack in the crankshaft. I checked with Maibach tractor since they are the closest to my area but had no luck. Does anyone know of one or have some ideas on where to look for a crank. I am in Ohio close to Dover and New Philidelphia where the national Oliver show is held periodically. Any help would be appreciated. I may even be interested in a whole motor but it isn't my tractor.
Don
I don't have or know where you can get a used one. But I have a 1755 with the crank down in it and I have been thinking about buying one of these new ones that some of the parts suppliers have. I would think this should be better then one ground all the way or even welded up. Maybe someone on this forumn has some experience with these new ones.
The new ones currently made are made of cast iron. If a steel C1046 steel forging that they used originally won't hold up, I would't put a cast one in. You're better up with a welded up original crank.
