Oliver 500/ DB 850 3 point problem
Hi, I have an Oliver 500 diesel that I"ve just gotten running after 20 yrs of sitting. I cant seem to get the 3 point hitch to work on it. I drained (replaced) the fluid and cleaned the pump screen (it was milky). Also I adjusted the nut (plug hole on top of pto <there abouts>), so that the nylon washer was loose by touch when the lever was in the up position. Still nothing. I"m at a loss now. Any advice would be great.
The tractor was parked because the steering box came apart. Its believed that the 3 pt worked when it was parked but nobody seems to know for certain. Thanks for any help
Danny
Might be sticky from sitting,if its up try to force it down then see if it raises,I had that one time on a tractor sitting out for a long time
Yes, I've dealt with that before as well.... I can move the arms by hand....amazingly everything is well lubricated and moves easily with the arms. I'm becoming more certain its a problem with the pump. Thanks for the response
