Oliver 55 and 88
Can someone tell me the year of an Oliver 88 with serial number 138332088F(the 0 could be a C or alpha O, not sure) and an Oliver 55 with serial number 49 158-518? Are they row crop, stardard, super, etc? The 55 also has a Specification Number 25-0087 on the tag, what does this mean?
Thanks.
go to the left of screen and look under serial numbers and you can find the year. A picture would help tell the type of tractor, Good luck Amo
The super 55 is a 1957; the -518 in that case is a transmission code. The specification tells what options the tractor has, the 25 means super 55.
I think that the 88 would be a 1952, non-super Rowcrop. Were there spaces in the number, or were they strung together? (I presume that you got the number from the serial number plate??? Where was it located?)
If it was a '52, it would have disc brakes unlike earlier versions...
The 88 serial number was all ran together and yes I did get it from the serial number plate located under the dash.
Thank you for the additional information.
