Tom Sanderson
Subject: 1965 550 Gas with approx 2000 hrs, has a Oliver 1550 front end loader
While I was learning how to use my power rake, I got fed-up with the left brake always sticking/dragging. Tore brake assemblies off to rebuild. Decided to fix some of the rear-end leaks also so I replaced both brake thru shaft lip seals and both rear axle seals. Lessons Learned, don’t use 10W30 oil in transmission as they recommend as it will all leak out. I used 80W90 even after I replaced 4 of the 6 rear-end lip seals.
I fought big time to remove the brake pack assemblies due to excessive corrosion on brake shaft splines. My splines have excessive wear and I just cleaned them up best I could by stroking a wire wheel on a 4” grinder axially to remove all the rust. Mice made nest inside the housing and I believe caused the sever corrosion. I cleaned everything else up really good, replaced all the brake balls, 4 springs, and put it all back together after replacing the seals. Oh yeah, I screwed up and busted the inner pressure plate on left side by over torquing 3 5/8” bolts. Kudos goes to Pell’s Farm Equipment in MI as they were lifesaver. They had a used one for the LS that was reasonably priced. I definitely recommend them for Oliver parts.
Finally my question: Everything works fine except, the left brake still seems to settle in to a dragging position, almost like a detent. I’m wondering if my spline wear on that side was bad enough that at least one of the splined disk is still catching and the return spring isn’t strong enough to overcome it? Difference now is that it will easily reset just by nudging the back side of the brake peddle. Is there any other reasons that might cause the LS brake to hang-up???
