Oliver 550 light wiring
super99
I am rewiring the lights on my
550 . All I had was 1 wire coming back from the switch. I need to branch off to 2 wires on 1 fender for front and rear lights and
another branch for wire to the other fender. I was going to strip the wire and solder them together, but then decided to just put eyes on the wires and bolt them together..I had some heat shrink covers and tried to make them work. I ended up with the bolts not covered, so I tried splitting a piece and going over the top, that didn?t work so I just taped the snot out of it and called it good. Chris
I got 2 lights working so far, the insides of the lights are so rusty I'm having trouble getting a ground. On 1, I had to drill a hole in the light and add a ground wire to the light bracket to get it to work. I even took the light mount bracket off of the fender and cleaned it up with the wire wheel and put new bolts in. I'll get the other front light working tomorrow one way or another. The last one has the bottom busted up where the bolt goes thru. I think I'll try to clean it up and weld a washer in the bottom and see what happens. I also have to make 5 pieces to hold the wire up against the fender so it doesn't get tore off. Chris
Congratulations, you have "re-invented the wheel"!
<img src = "https://www.grote.com/wp-content/uploads/2014/07/84-2381.jpg">
LOTS of sources out there for similar connectors. (Not that I would ever use one, there's lots of neater ways to get the job done.)
(Just giving you a bad time, mostly, hey, if it worked for you, thumbs UP!)
