Oliver 550 shift issue
oscar80
My tractor was a basket case when I got it. The previous owner got half way thru a clutch job and stopped. My friend has the clutch back in and the PTO back together. The tractor now starts at least.
The next issue that we have found is the only gears that it will go into are 2-3 it wont go over to 1 and Reverse. It seems the the right rod looking down has pivoted because we cant see the indentations. Is this from bent or broken forks or something else. Going to remove the top soon. It also doesnt seem to want to shift between hi-lo. Bumping the starting while its in 2-3 the tractor does move. and it will go into neutral.
Thanks,
Dave
Pulled the hydraulic section this morning and found out what the issue is. the previous owner didn't put the right side shift rail all the way forward and also the right(front) shift fork was broke at the place were it mounts to the rail. So I will be calling Kent in the morning.
Dave
