I can't think of anything bad to say about one. Tough as nails. My wife still to this day has a little trouble shifting one, but she tries too hard. They're a thumb and two finger shift and she gets right down in the seat and acts like is more work than it is.
They have independent PTO, not a 2 stage clutch, live hydraulics.
In my opinion they are one of the most well designed Utility tractors in existence. Desirable, reliable, and with good ergonomics. So with that recommendation, the decision to buy should be based on its condition and the condition of rear tires. If it has straight tinwork, runs well and you can operate it for an hour with no smoke or excess blow by, and the gears hydraulic system, and steering seem good. It will serve well. Jim
We had one on the Farm back in its day brought new. Out of four, under 50hp tractors, it was our main go to tractor. Easy to handle and drive and good power for its small size. The pto clutch or something was slipping when it was sold in Dad's auction in 1972. It would slip when put on the baler so didn't use it for heavy pto work the last year or so. Last I knew a collector had it and was all fixed it.
My son has a 550 with a loader. It's been tough, reliable and handy little tractor.
The one weak spot seems to be the power steering. While it works it's been plagued with leaks from both the steering cylinders and the pump. Also the generator recently quit working. This is somewhat problematic as the PS hung onto and driven off the rear of the generator. This makes the generator somewhat of an oddball - replacement or rebuild may be difficult.
He'd like to do a 12 volt alternator conversion to get rid of the generator. But this requires cobbing up an alternate belt-driven steering pump, or adding an alternator and leaving the inoperative generator/pump in place to drive the pump.
Aside from the above it's been a very good tractor for him.
